Weiand Superchargers?
Are these superchargers good for street use? If so is there any way to fit the supercharger in the link below on a 351w?
http://www.holley.com/types/Small%20...4%20Series.asp
RE: Weiand Superchargers?
are you running a carb or stayign with fuel injection. Smog may be an issue with the carb.
Have you checked out Kenne Bell. I have one with 8psi and still fuel injected. They add 100 ft lbs at 2000 rpm becuase it is a twin screw design. More efficient (lower temperature air charge) then the weiend roots style.
www.kennebell.net
http://www.kennebell.net/supercharge.../mustang50.htm
I bought mine on ebay, recently rebuilt and with 0 miles after rebuild for $1800.
www.kennebell.net
The 3 lobe roots blowers aren't that bad for street use, kiss your gas mileage good bye though. I am not sure if it'll sure on you or anything. I would call them and ask. I would get a stronger crank though cuz I have heard that kinds of blower puts alot of stress on the snout of the crank.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
