No mufflers
RE: No mufflers
ORIGINAL: ZachW04Stang
Like previously stated nothing is going to happen. If you had just open shorties then you might burn your exhaust valves up but you should be fine. You would probably notice better performance if you put your mufflers back on though.
??? How???
ORIGINAL: AdderMk2
it is possible to bend your pushrods with not enough backpressure
RE: No mufflers
ORIGINAL: AdderMk2
to be honest with you.. I have no clue... it was something my boss told me when i was driving my car around the shop with just my shorties and X pipe. He said (dont rev it up, you can bend a pushrod because you dont have enough backpressure. I believed him because hes a Master tech, fully certified ASE technician with 37 years experience.
??? How???
ORIGINAL: AdderMk2
RE: No mufflers
ORIGINAL: Twisted
So, Adder, are you gonna school me on the merits of SD bumpsticks, or what?
ORIGINAL: AdderMk2
i really need to study for more of the tests... i only have suspension and brakes as of now
RE: No mufflers
ORIGINAL: AdderMk2
all i can really "school" you on is that if you install 1.7 roller rockers, you will have all the same cam specs as a 5.0 cobra with the exception of the lobe seperation angle
ORIGINAL: Twisted
ORIGINAL: AdderMk2
RE: No mufflers
ORIGINAL: AdderMk2
RE: No mufflers
What mufflers do you suggest using if I were to put some on. I'm looking for a loud low toned rumble at a idle. Thanxs for the help so far guys.
[IMG]local://upfiles/8760/A185591C662E45A3980CEF85A986DBEB.jpg[/IMG]
