No mufflers
No mufflers
I have a question about my exhaust on my 88 stang. I have the stock headers going into a x-pipe and from there my exhaust goes out the back of the stang with no mufflers. It sounds really good and it has a low rumble that I really likebut I'm worried about maybe causing some damage considering I don't have much backpressure.Should I worry? It runs really good with absolutely no problems. Also what do you guys think about that additive you put in your antifreeze called Water Wetter? Does it really do what it says and lower the temp. of your radiater by 20 degrees? Thanxs in advance for your help.
[IMG]local://upfiles/8760/A1945205F1034F6FBC5CF2295DC217FD.jpg[/IMG]
RE: No mufflers
I'm curious about both questions too. In terms of exhaust, I know that on carbureted engines, if you have no mufflers, and stock carb jetting, the motor will run lean. I doubt that happens with EFI though. I also once heard...and this may be a myth, as it sounds silly...that not running mufflers allows cold air to rush back up the exhaust when you turn the car off, and warps your exhaust valves. LOL. Hopefully someone will chime in and set us straight.
RE: No mufflers
Youre not causing any damage with no mufflers. If your exhaust was too short, or open shorties you can burn a valve up that way.
As for water wtter, Ive heard that it works, changes surface tension of water or something like that.
-P.
-P.
RE: No mufflers
ORIGINAL: AdderMk2
it is possible to bend your pushrods with not enough backpressure
Ahh. 3k posts! That was my goal, and now I'm done with this forum. Take care everyone.
RE: No mufflers
Hey man thats just your opinion--my stang DOES NOT sound like ***. I sure as hell wouldn't be driving it around if it sounded like s**t!! I'm sure if you heard the way it sounded you wouldn't think so! By the way what does "***" sound like?
[IMG]local://upfiles/8760/7FA4AD15680747CA9F30174EA5792465.jpg[/IMG]
RE: No mufflers
i ran open shorties for about 10 miles bad idea now i have valve float like a mother past 5k so i cant get full out of my car you are perfectly fine wtih your exhaust the way it is dont worry about anything happening its not short enough to have the cold air rush back in and warp anything you are good to go
RE: No mufflers
Like previously stated nothing is going to happen. If you had just open shorties then you might burn your exhaust valves up but you should be fine. You would probably notice better performance if you put your mufflers back on though.
??? How???
ORIGINAL: AdderMk2
RE: No mufflers
ORIGINAL: ZachW04Stang
??? How???
ORIGINAL: AdderMk2
