lengthening the engine bay wires
RE: lengthening the engine bay wires
When you do that, on the driverside, you should only have to extend a few wires(wiper motor wires I had to, and the booster wires) Just be prepared for the inner fender to not fit well after you put the wires in there, if you use the existing holes. I had to use a little heat to form the plastic around where the wires were, but it worked out good.
ORIGINAL: megatron40
does anybody know the best way to lengthen the engine bay wires to conceal them out of site.
I don't have pics of pass side, but does require lengthening of a few wires. Take your time, solder and shrink wrap all connections.
ORIGINAL: JeffUtica
Pics of driver side here.http://www.cardomain.com/ride/791057/7 I didn't have to lengthen any on this side although I did unwrap which made them longer and fit through the holes.
ShaneB26154
35
03-04-2021 04:05 AM
09-01-2015 08:16 PM
