1968 289 Engine Question
Old 12-31-2006, 03:11 AM
roscioa
roscioa's Avatar
Default 1968 289 Engine Question
I have recently taken my 11 year old engine and changed the top end. I have put an Edelbrock performer RPM heads, cam, timing chain, Air Gap intake, and 600 CFM carb, and roller tip rockerson it. It runs good but does not seem like it has a very high RPM capability. I have only had it up to 3500 RPM since it seems like it is struggling to go any farther. I thought it should be able to at least go to 5500 or maybe 6500. It was going further then that before with everything stock except for the intake and carb (same as above). I was wondering if anyone had advice. I am using the stock fuel pump and distributer with a pertronix igniter. How can I get more from this motor. It runs good and sounds good, and will a dyno tune help me at this point? It has a 3spd which I know is limiting the car and 2.73 gears. Any help would be nice. Thanks.
roscioa is offline
Old 12-31-2006, 03:26 AM
iceman89gt
iceman89gt's Avatar
Default RE: 1968 289 Engine Question
i would say intake but it would usually only make it reach max rpm faster if its better for bottom or slower if better for top but, i dont know 3500 aint sh** i stall up at 3000 on the line with a 306.
iceman89gt is offline
Old 12-31-2006, 03:29 AM
iceman89gt
iceman89gt's Avatar
ill ask father in law tommorow hes a 289 smart guy, i just helped him pull one out of an old 68 ford pickup. so old ants were in the carb. i had to crawl under it in the weeds and mud and cut the mounts,headers,tranny cross member with torch then pull motor tranny and all out with trackhoe. he had to have it though lol lol lol
Old 01-01-2007, 08:05 PM
roscioa
roscioa's Avatar
Thanks, I bought a compression tester to check the motor out. I will try that tomorrow hopefully. The only other thing i can think of is the fuel pump is not putting enough out causing it to not want to go. Maybe also I need an electronic ignition? I have no clue really. It would go to 4500 easy before I changed things.
roscioa is offline
Old 01-01-2007, 10:22 PM
tinman
tinman's Avatar
I'll bet money that the fuel pump is the problem. Get either a Carter or a Holley pump from Summit or someplace.
You'll pay for it but I'm thinking that's the problem. You are not getting enough volume at carby to run it faster. Also look for a crimp in the gas lines.........
tinman is offline
Old 01-01-2007, 10:55 PM
nitrous_bob
nitrous_bob's Avatar
fuel or spark, did something get cut, burned , loosened up, or not connected all the way ?
did the dizzy go back in correctly ?
nitrous_bob is offline
Old 01-01-2007, 11:03 PM
ZachW04Stang
ZachW04Stang's Avatar
Whats your timing at? Did you check with a timing light to see if it was advancing spark at higher rpms?
ZachW04Stang is offline
Old 01-01-2007, 11:11 PM
93 LX FiveO
93 LX FiveO's Avatar
check throttle linkage
93 LX FiveO is offline
Old 01-03-2007, 09:37 PM
roscioa
roscioa's Avatar
I called Edelbrock today and they stated the same thing that my stock fuel pump would not handle the job. I will have to figure out what pump I want to go with now. I will also check the timing again but I think it is good. I will update when I get the new pump. Anyone have a suggestion whether to go with an Edelbrock bolt on or with an electric in-line pump?
roscioa is offline
Old 01-03-2007, 09:54 PM
ModularFox
Banned
ModularFox's Avatar
i know its off topic, but those 2.73s are KILLING your performance. the car would act 100% better with some 3.73s or 4.10s
ModularFox is offline
Quick Reply: 1968 289 Engine Question
