Question on Engine V
Old 07-23-2003, 09:34 PM
dsg02
dsg02's Avatar
Default Question on Engine V
Not that long ago I bought a 95 GT with about 120,000 miles. I noticed the engine got pretty rough at higher RPMs and I replaced the balancer. Initially it seemed a lot smoother but now I still think the engine seems pretty rough say above 4,500 RPM. It doesn't burn any oil, I've replaced the dist cap, coil, wires, fuel filter, etc. - it doesn't make any strang noises at idle or anywhere else.
Am I being paranoid? Is it just what a 5.0 feels like at higher revs after 120,000 miles? Could it be something else more serious? I don't have alot of experience with V8s - maybe I'm just paranoid.
I know the engine revs to about 6,000 but it feels like I'm torturing it about say 5,000. Up to 4,500 it seems really smooth.
It is the engine and not the driveline because it feels the same way in neutral w/o any load.
What do you think?
Thanks,</P>
Greg
</P>
dsg02 is offline
Old 07-23-2003, 09:55 PM
Sean
Sean's Avatar
Could be something else, D shaft, U joints, or clutch going bad?
Sean is offline
Old 07-23-2003, 10:30 PM
dsg02
dsg02's Avatar
It occurs even when I rev the engine up in neutral.</P>
</P>
Thanks,</P>
Greg</P>
dsg02 is offline
Old 07-23-2003, 10:51 PM
makarovboy
makarovboy's Avatar
You didn't mention if you had the auto or stick. If it's an automatic, I would be checking the converter to flexplate. If the converter is loose or the flex plate is damaged, it could cause vibration. If it's a stick, I would check the tightness of the pressure plate to the flywheel or for clutch damage. All these parts rotate when the engine is running, regardless of what gear you're in or in neutral.
makarovboy is offline
Old 07-23-2003, 10:55 PM
Buzzstang
Buzzstang's Avatar
could be the flywheel
Buzzstang is offline
Old 07-24-2003, 12:58 AM
dsg02
dsg02's Avatar
Thanks for the replies. It is a 5spd BTW.
dsg02 is offline
Nick Oliver
10-17-2018 04:22 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
TfcCDR
09-14-2015 12:08 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Question on Engine V
