Water Pump
RE: Water Pump
yes it really is that simple only one way to learn pick up the manual(15$, the pump 40$and a new serptine belt while u have it apart 20$) read the instructions throughly and go to town on it!
RE: Water Pump
Here are some pics on how to remove the fan, shroud, and AC compressor / Power Steering bracket to have full access to the water pump. First off, take off the serpentine belt.
These are the two bolts to loosen the fan shroud:
These four bolts hold the fan and pulley on: (yes I have a coolant leak or two [:@][:@], will fix them soon)
Once both of those are loose you can lift the fan and shroud out together (the shroud is held in the bottom by two metal clips). Be EXTREMELY careful with the fan, you don't want to punch any holes in your radiator.
After the fan and shroud are out you'll have to remove this bracket which the AC compressor and power steering pump are attatched to (the big brown one):
Just set the power steering pump aside down there, the AC compressor should still have (I think) a bolt or two holding it in after your remove the bracket. You'll now have complete access to the water pump. Undo the hoses, then unbolt the old pump, clean the gasket contact surface, put the new gasket and pump back on. Repeat disassambly in opposite order to get it all back together. I found it nice to put a piece of cardboard between the shroud and radiator to make sure you don't punch a hole in the radiator with the fan. Good luck, don't hesistate to ask any questions.
jwog666
12-27-2021 08:09 PM
