Can I please get a correct answer ?????
RE: Can I please get a correct answer ?????
no if u run the factory belt routing way and you deleted your smog, your putting that sharp turn on a small pulley and you will bust your belt, it happened to me, i re-routed my belt differently then factory way, and i have under-drive pulleys so if you have ud pulleys and want to route it a good way let me know and ill get you my size belt tom.
i found the string trick didnt work quite right i still ended up off by one belt size, i did the same thing hes doing on my old 86 notch...i didnt have much adjustment compinsation on a bigger belt cus of the crappy tensioner
ORIGINAL: 93stangz
just use a string to find the lenght you need
ORIGINAL: Ecstasy
well you dont race your car either lol, ive had 2 belts bust on me because of that small pulley and sharp belt turn. so i re-routed mine.
