how do u tell if a torque convertor is bad???
RE: how do u tell if a torque convertor is bad???
so its not supposed to make any noise??? even if its outa a dodge inteprid p.o.s. car???i asked on here cus the dodge site itnt all that active, and i know i always get good help on here...tryn to fix the pos so i can have money for my stang!!lol
ORIGINAL: mattdel
no not at all
no not at all
by the way this is when its sitting in my lap not in the car, but my car was making a wobbly noise when i put it in gear till i took off above a idle, then it started leaking out the front of the tranny but the front seal looks ok, so i dont know what the hell im dealing with now, 2 flexplate bolts were a tad loose so that may have been the wobbly clunk clunk sound when in drive but not moving, it did it moving to but only at like 5mph
ORIGINAL: Li0nHart
if its jus a stock one and you have it out of the car...just buy another one.i think they range from 100 to 300 bucks...
yes it u will be able to hear the inside moving around if u shake it iseriously doubtr u have a bad torque converter its just a turbine that mounts to the input shaft and redirect the fluid
If you're shaking it and it's not on the car your going to hear some stuff moving around inside of it.Stuff WILLmove around inside if you're shaking it and it's off the car.
