speedo issue
Old 01-02-2007, 04:10 PM
white91fox
white91fox's Avatar
Default speedo issue
i have a speedo that is not working. i have a 91gt had a stock aod the owner befor me swaped it to a t5 world class. i replaced the cable. nothing, i replaced the pinon gear and seal that hooks into the side of the tranny, still nothing. is there a gear that sits deeper in the tail of the tranny? if so could someone tell me the name or part number of this? thank you for your time
Matt
white91fox is offline
Old 01-02-2007, 04:13 PM
Hawk
Hawk's Avatar
Default RE: speedo issue
There should be only one gear in the tranny. Did you check the speedo cable to make sure it wasn't binding? It might just need a good greasing. Or it could be in the speedo itself.
Hawk is offline
Old 01-02-2007, 04:17 PM
tmajikman
tmajikman's Avatar
what about the part inside the tranny that spins the gear on the cable, can that be checked.
tmajikman is offline
white91fox
white91fox's Avatar
new cable and i even pulled the cluster and drove down the street not even one turn on the cable. i was thimking you know how you change gears in the rear you need to get that little plastic gear ie. 3.55 to 4.11 so the gauge will read right. maybe its striped or not even there
15austin
15austin's Avatar
Did you make sure the new cable is in the back of the speedo right? There is a gear inside the t5 on the tail shaft it self. You can feel it by putting your finger in there. if you think the cable is right, take it loose from the t5, have someone look at the speedo and spin the gear on the end of the cable wiht your hand and the speedo will move. if it dose it is in side the trans.
15austin is offline
Old 01-02-2007, 04:20 PM
15austin
15austin's Avatar
If the cable is not turning driving down the street, then it has to be the plastic gear in the trans or on the end of the cable.
15austin is offline
white91fox
white91fox's Avatar
yeah its spins when off the trans. i just must be missing that gear inside the tail shaft. think so? anyone know where i could get one?
Old 01-02-2007, 04:23 PM
15austin
15austin's Avatar
Dop you know you have to take your trans appart to get that gear in there? that tail shaft housing dont just unbolt off there.
15austin is offline
Old 01-02-2007, 04:27 PM
white91fox
white91fox's Avatar
so i need to drop the whole damn trans to change a little plastic gear? yeaaaa. this is gonna suck . well never mind my car must be a freak. 6 bolts and i can pull off that tail shaft housing. is there a better way to check?
Old 01-02-2007, 04:33 PM
15austin
15austin's Avatar
there is a way you dont have to, but taking it out would be a hole lot easier. so pretty much if you want a speedo, trans needs to come out. ( if for sure the gear inside the trans is the problem)
15austin is offline
Quick Reply: speedo issue
