T5 leak!!!!
T5 leak!!!!
my T5 on my 87 mustang is leaking real bad. its go no fluid that i can feel when i stick my finger in the tranny. i was wondering if it was the rear main seal or the front main seal that is bad...or both
RE: T5 leak!!!!
take 2 or 3 cans of brake clean and spray that bitch down, get it clean and then let it sit for a few hours and go look at it. then you should beable to see what half of the tranny is leaking... and there are no gaskets on a t-5 or a front seal only a few o rings and a rear seal... the rest is all a silicon (sp) i personaly use marine RTV (main in the *** to ge the tranny back apart tho)
RE: T5 leak!!!!
engine oils look nothing like ATF (automatic transmission fluid) it's easy to tell the difference by smell and color... and from the factory the front bearing retainer isn't sealed for **** so if it's all over the front of the tranny that would be a good place to start
