idle air control
01-02-2007, 08:09 PM
idle air control
if i were to eliminate the iac what would happen
01-02-2007, 08:26 PM
RE: idle air control
your motor would not run.
edit: it will run, but will not idle. it will die when u come to a stop, if you can even get it going fast enough to need brakes
01-02-2007, 08:36 PM
Mine ran better without it.
01-02-2007, 08:40 PM
Quote:
ORIGINAL: PX429
uhh.... i believe you are mistaken...
01-02-2007, 08:43 PM
nope. i made a gasket to cap off the IAC and worked fine after that.
01-02-2007, 08:46 PM
Quote:
ORIGINAL: PX429
well see.... you shoulda said that.. thats a different story
01-02-2007, 08:47 PM
huh? hows that differant then completely removing it?
01-02-2007, 08:58 PM
gaping hole vs sealed hole
01-02-2007, 09:00 PM
Removing the IAC but not capping off the opening would create a giant vacuum leak!
01-02-2007, 09:02 PM
also just unplugging it will cause it to die
