solid tranny mount or poly mount for a wc t-5
about to change tranny mount on a world class t-5. just thought about solid mount and i have heard of poly mount. wondering if anyone is running either and what some of the pros and cons are on them. thanks guys
RE: solid tranny mount or poly mount for a wc t-5
ORIGINAL: AdderMk2
poly is better...
poly is better...
If you have a poly trans mount, make sure you have poly motor mounts or solid motor mounts. If you have a solid trans mount make sure you have solid motor mounts. If you had rubber motor mounts and a solid or poly trans mount the motor would twist from torque on the motor mountsmount and the trans would be held in place because of the stiffer mount and you would risk cracking the trans case.
ORIGINAL: ZachW04Stang
Actually solid is better because it allows more torque to be transfered to the wheels. A poly mount will allow less vibration through the chassis though and is much more suitable for daily driving.
ORIGINAL: AdderMk2
poly is better...
poly is better...
my car is a DD, so i go for comfort... solids are great, they never wear out, but i have a massage chair at home.. I dont need one in my car as well!
ORIGINAL: AdderMk2
yea, there is always miscommunication with when i say something is better than something else....
ORIGINAL: AdderMk2
poly is better...
poly is better...
i'll agree with all of this except the maybe cracking the tranny case... you WOULD crack the case its just a matter of how long it would take... all of you bushings should match the only exception i can see is a softer one on the tranny then the motor has, but that doesn't do a damn thing. iagree with adder,solid for a weekend warrior or track car, and poly for a DD
ORIGINAL: AdderMk2
poly is better...
poly is better...
thanks for the input guys, im probly going with the solid because i have solid motor mnts. and its a street car but only when someone wants a $ race. the rest of the time its track car.
