oil pan woes
oil pan woes
i was talking to a friend about my oil pump dying and such when he told me to drain the iol check it for metal shavings and drop the pan. Do i have to hoist the motor to drop the oil pan? i think i do.... im planning on doing it when i get home from work in 2 hours and just want to know what im getting into.
RE: oil pan woes
Yes, you will need to jack the motor up a good 3-5 inches, you'll need a cherry picker, because you cant jack the motor from under neath (where the oil pan is). You can make an engine cradle out or some 4x4's and brace it over the strut towers and use truck tie downs to hoist it up,(done it but not the safest)and lower it back down after the swap with a jack. Be prepared to clean the floor... lol it's messy![8D]
RE: oil pan woes
i'm really looking forward to this now......dont think i'll try the "hoist " method, but any tips to make it easuer are greatly appreciated. I expect my keyboard to be covered in 10w-30 by the end of the night.
RE: oil pan woes
I didn’t know if the photos would show up so I put them here. http://www.cardomain.com/ride/791057/15
You can get away with an engine lift, but it leaves very little room to work under thecar. Reason I fabbed up a quick and dirty hoist out of 2x4’s and tow straps.
1.) Remove the (2) bolts that secure the rack to the K-member
2.) Loosen the pinch bolt on the steering shaft.
3.) Slide rack forward and down far enough for the oil pan to clear.
4.) Drain coolant
5.) Remove upper radiator hose. You won’t be able to raise the motor high enough w/out over stretching or breaking this hose.
6.) Remove fan and shroud. The oil pan hits the shroud.
7.) Loosen the (2) trans nuts, but DO NOT remove them. You want the nuts partially threaded on otherwise it might pop out of the holes and make it a royal PITA to line back up.
8.) Remove the motor mount nuts.
9.) Raise motor until the bell housing hits the firewall.
10.) Once raised, put blocks of wood between the motor mounts and k-member as a safety measure. You don’t want the engine lift to accidentally unlock and drop the motor while your hands are in there.
11.) Remove all the oil pan bolts.
12.) Drop pan, but do not remove yet.
13.) Unbolt the oil pump and let it drop into the pan.
14.) With the pump in the pan you can now remove the pan. Slide forward, angle down, then out she comes.
4.) Drain coolant
RE: oil pan woes
ROYAL PITA ! NOTHING LESS
take the Radiator out.
also the pan will ony drop so far, the pickup tube bolts have to be removed before the pan will clear it from the motor and and cant really see them, just feel them.
You sure the pump went out and you dont just need the shaft, or perhaps you have a bad sending unit?
RE: oil pan woes
ORIGINAL: JeffUtica
4.) Drain coolant
4.) Drain coolant
RE: oil pan woes
i suppose it could be the shaft or sending unit...i dont really know. I drove the car bout 20 miles from my house after warm up......then the pressure just stoped at idle. I want beating it and there was plenty of oil in it....so how do i check if its the sending unit or shaft.....or do i still have too drop the pan?
