What are some cheap cylinder heads I can use on my 94' GT
I have an Edelbrock Performer intake and cam, 1.7 cobra rocker arms, BBK shorty headers, 70mm throttle body, BBK cold air intake, 2.5 inch high flow H-pipe, Magnaflow cat back exhaust. The car put 220 horsepower to the tires with an automatic in it. The car was custom tuned and they told me without cylinder heads or forced induction I was about maxed out with the engine. I am looking to put some cylinder heads on it but I want to spend as little as I can but still make a good difference. What should I use. I have heard that older 351 windsor heads work but I don't know if they will on an efi engine.
RE: What are some cheap cylinder heads I can use on my 94' GT
ORIGINAL: Darrins94GT
c&l ? those are great to build on, and tune for larger injectors if you ever decide to go w/ a power adder, they can be tuned up to 42 lb injectors.
Take a look at Arrowhead Products in Indianapolis, 317-862-0223.
For $399/pr assembled you get select Windsor castings, like new appearance with milled head surface.
3 angle valve job,bronze liners, 1.90x1.60 stainless valves and .550 lift springs.
They accept all stock parts.
If I hadn't lucked out on a used set of aluminum edelbrocks I would have bought these.
Good luck.
Good luck.
