EGR REMOVAL
RE: EGR REMOVAL
I thought the plug makes the computer think the egr is closed all the time.
Estasy: How did you get the egr delete spacer on there? I have one and I tried to put it on but the throttle cable bracket hits the coolant lines that go to the heater core.
RE: EGR REMOVAL
ORIGINAL: 5.0stanger
I would like to know too
ORIGINAL: 88BlueGT
So basically the only thing that plug does it stop the CEL from comming on?
ORIGINAL: aode06
do ONLY hard codes or keep alive memory codes effect a/f ratio? OR BOTH
aka the ones that set the light, and the ones that only appear in a scan
RE: EGR REMOVAL
So technically, you could just unplug the sensor and it would be the same as the simulator, minus the CEL, right? All the simulator does is keep the light off, right? The rest (elimination of the function) is done atomatically be the computer, right? I just want to get this straight, my CEL is burnt out, and I have eliminated my EGR by keeping the sensor inplace, minus valve, with the plunger held part way in, but I wanted to get a simulator to do it right...but if all it does is keep the light off....I don't have that problem. Sorry about the run on, and on, and on...but I have wondered this for a while.
RE: EGR REMOVAL
RE: EGR REMOVAL
ORIGINAL: Glasersil
Whats the point of doing this? Any HP?
infact when i blocked of the egr on a 2.3l and tried it with th egr plugged in and not plugged in the car ran like shyt either way i did it and same when i did it on a efi 5.o! both motors ran alot worse
RE: EGR REMOVAL
simulator = no CEL
To delete EGR = unplug EGR sensor
Just making sure bc you can play with the plugger on the sensor with my engine and if it is all the way out (EGR open) the car runs like crap and if you push it in half way (EGR closed) it runs great. I just want to make sure before I do anything.
RE: EGR REMOVAL
ORIGINAL: Joel5.0
[sm=exactly.gif]
