Bad choice ??? how can i fix it
#21
RE: Bad choice ??? how can i fix it
ORIGINAL: 91sleeper
hey guys i need help i'd really like get a set of weld rims with sum et street drag radials for the backs but i'm looking the $$ for this stuff new and when u times all the prices by 4 it gets expensive. Whats a good price to pay for a set of used welds (4) with/without tires ??????
1st off DON"T LISTEN TO POLE WHO DON"T KNOW $HIT , if they say it's too big they are dumb
you want a 3000+ converter , i had a 2200 in my '90 GT it was too stockish , hardly noticed a diff, first of all, even a 'vert is lighter than the figured weight for advertised stall speed. my '90 lx 'vert was 3400 lbs w/ 1/2 tank , the lighter the car, the lower the stall speed w/ the same converter, the lower the HP the lower the stall speed, i think you'll be lucky if you flash at about 2700 , so it is not by any means too big.
thats the starting point , go up from there, on a true dd i'd go 4.10's and 3500 w/ a c4 w/ the lower 1st gearset (2.8X) not so much DD then 4000-5000
but i use no less than 4.10's on my 5-speed cars
#22
ORIGINAL: turbosha
i think your origanal set up it good go with the 4.10's and 3000 stall. you'll like it. your car isnt making monster torque right now,so it wont stall that high.add some power to the engine and the 3000 stall will shine. make sure you use a big enough trans. cooler with any trans upgrades. heat is a trans biggest enemy.
#23
thanks alot guys i figured the converter topic was dead i didnt get many responses at first. I just ordered the 410's today got the ford ones NOT the "morso" ones... at least i dont think the part number is FMS-M-4209-G410A , I'm pretty sure i read that u want the ones with the part number ending in "A".
How much more power will i need b4 i need to wry about running out of gear by the end of the track??? Ohh and the tranny cooler i bought was the B&M supercooler i hope it'll get the job done and is okcuz iguess i already went wrong with the torque converter brand aparently lol
http://store.summitracing.com/partde...p;autoview=sku
#24
K sry u might have misunderstood that ^ , I did order that part number for the gears because they are suposed to be the Ford ones and not the Motive ones i think i put morso sry bout that and any comments on that tranny cooler ? is my TCI converter really that bad... its not gonna like break or somthing will it, its not like my car is crazy fast
#26
Need help guys with me rear end I do believe it it to be stock and I want to run this weekend at the track I don't know if I can beat my friends time of 3.63 in the 1/4 mile. I have done just about every bolton you can do except gears just put in a billet aluminum flywheel and new clutch, aluminum drive shaft. I have a five speed. with 302.
#27
The 3000 will work well, even with the car not havng much done.
Also you don't need a manual vavlebody. All you need to do is use the 1-D-1 shuffle and it will kick when you want it to. Just remember when you kick it back to one to shift from second to third, they is a slight hesitation so shift about 400 rpm short of what you are aiming for.
Feel free to P.M. me any questions you have on the AOD, I have tons of experiance with them. MY AOD GT, I had it running 12.50's with stock heads, cam, and factory convertor.
#28
ORIGINAL: iehotrod
Alum. FW's help your rpm's drop faster. For dragstrip performance, you want the heavier rotational mass of the stock (or steel) FW to keep the rpm's up.
zanemoseley
09-06-2015 12:58 PM
