Radiator and Cooling Fan
RE: Radiator and Cooling Fan
You can easily do it in less than two hours...even if you're really slow. I installed a new oem radiator, and am using the stock fan, and the car never gets above 195 degrees...even in So. Cali summers. On the other hand, I've heard of guys' cars running hot while using expensive radiators and fans--I guess if their not matched up correctly. You'll have to decide which route you want to go.
ORIGINAL: Twisted
You can easily do it in less than two hours...even if your really slow. I installed a new oem radiator, and am using the stock fan, and the car never gets above 195 degrees...even in So. Cali summers. On the other hand, I've heard of guys' cars running hot while using expensive radiators and fans--I guess if their not matched up correctly. You'll have to decide which route you want to go.
more coolant than water and your car will run hatter
more water than coolant and your car will run cooler
