T-5 Removal
T-5 Removal
My clutch is new, but the trans need to be replaced. Can the trans be removed from the bell housing, leaving the BH in place? Thatis, can I remove the 4 bolts from the trans to BH and slide the trans out not disturbing the clutch, etc?
RE: T-5 Removal
No....take the bell housing off with the tranny. You will not disturb the clutch because the pressure plate is bolted to the the fly wheel enclosing the clutch.. While you have it off, you can check the conditionof the pressureplate, and clutch. Even if it is new,better to have peace of mind. Better to look now and see if you have to replace something then later and do it all over again. Alsothink about getting a new throw out bearing also.
RE: T-5 Removal
ORIGINAL: SSKiller
No....take the bell housing off with the tranny. You will not disturb the clutch because the pressure plate is bolted to the the fly wheel enclosing the clutch.. While you have it off, you can check the conditionof the pressureplate, and clutch. Better to look now and see if you have to replace something then later and do it all over again. Alsothink about getting a new throw out bearing also.
RE: T-5 Removal
what i do is take the tranny off the BH (easier to get it out from under the car w/o the BH) then i take the bellhouseing off and and put the 2back together b4 i put them in
RE: T-5 Removal
ORIGINAL: AdderMk2
He's trying to say that you should ALSO remove the bellhousing after the transmission is out to inspect everything
RE: T-5 Removal
im doin it next weekend i think, i can tell ya how i did it then if u can wait that long.
my plan is to unbolt the mid pipe, drive shaft, and tranny cross member, unbolt the trans, slide it back, and drop her out, and then put the new(rebuilt) one in. should work that way, i can let ya no if anything ****ed up so u can no to look out for that
