how do i remove the ignition lock?
RE: how do i remove the ignition lock?
OK, if' it's the car under your avatar. Remove the plastic housing on the column. Look under where the lock cylinder is you will see a lil hole w/ a pin sticking down thru the hole. Turn the key to the run position, take something small enough and push the pin upward and then pull the lock cylinder out. It's very simple to do.
then you use a nice big screw driver to start the car....car stealing 101
ORIGINAL: 351w8bang93stang
of course if its not your car and you dont have the key it wont work, must have the key, so say u lost ur key, it doesnt come out very nicely
09-25-2015 06:58 PM
