VIBRATION FINALLY FIXED!!!!! THIS IS HOW I FIXED IT!!!!
Ok guys,i had to post on fact that i fixed my stang FINALLY!! i had the issue of is the 88 motor i swapped for my blown 95 externally balanced or not,well it is and i had to put in a weighted flywheel and a balanced harmonic balancer and the vibration i had is completely GONE!! so if any of you guys swap a 95gt motor for a 93 and below,just know that you have to get a new water pump so the pullys will line up and you need to get a flywheel and balancer that are BALANCED...alright then.....
RE: VIBRATION FINALLY FIXED!!!!! THIS IS HOW I FIXED IT!!!!
No one cares, too much to read... Summarize your whining...
LOL....
good tip though.... [sm=smiley20.gif] |
wow dont be so harsh dude, thats good that you found out your prob, now doesnt sucess feel great :D
GR84U Is A Rapist....hahaahahahaha....stop hatin you jealous mark!...lol...
thats good to know ..i never knew you had to do that
So did you balance the flywheel AND the balancer? I've heard of balancing a flywheel, but a balancer???
good tip! thanks!
Yea,that was the poblem all along, i had to balance the flywheel and match the same exact weight on the balancer (aftermarket) ,if you dont you will have a vibration that will drive you crazy!
Ah... I see now, so then the flywheel and the harmonic are the same weight now. Something tells me you didn't figure that out for yourself; that you had to consult with the machinist dude. :D
