After rebuild from 331 short block, car won't crank
I just got everything back together with a new 331 bottom end from DSS. Everything is hooked up but the H-pipe, i turn the key once dash lights come on, turn further and absolutely nothing happens, no sounds or anything. I am only trying to build oil pressure so i haveno plug wires or EFI fuse in. Any ideas????
RE: After rebuild from 331 short block, car won't crank
i have the ground from the back of the head to the firewall, the ground for the neg battery, is there a ground for the starter? i only have one kinda big wire going from starter to the relay, anything specific for me?
sounds like you have loose connections, or bad grounds. there is like 3 ground wires commming from the battery. Is your starter still good? Solenoid bad?
ORIGINAL: G2298
