Hooked suspension
RE: Hooked suspension
What tires do you or anyone on here recommend for street to hhok well? As fas as wheels Im onlt running the ponies. But my tires suck. I would like to get something that hooks.
ORIGINAL: nitrous_bob
try this, you can TO A POINT have a dual purpose suspension setup
mega-bite jr LCA's will improve handling and hook in a HUGE way
the right side airbag ($30 by itself) helps launch a lot
kyb at all corners will be noticible alot
energy suspension poly kit with everything else i said will make it handle like an older vette , and also increase the traction loads
but the bottom line is this, w/out a good tire (no street tire will do gotta be a DR or better) you will never be able to launch any higher than idle and slip the clutch til your going, it just won't happen , hook is MOSTLY about the tire
but the things i said will drastically improve handling, and greatly help traction
ORIGINAL: 5liter87
maybe 5% of that at the track, so is a drag setup worth it? i mean, if im going to be hitting corners hard and fast, i suppose i wouldnt want that setup right?
Matt's 95 Stang
10-05-2015 07:16 AM
