Hooked suspension
Hooked suspension
For some reason search function isn't working for me to well. Trying to do my research on what struts to get. Right now my car handles like poo, and looking for the quick way to help that out. Not going to use DR, but want a minimal burn through 1st when taking off. What should i do, jus get a shock/strut/spring kit from 5.0resto?
RE: Hooked suspension
shocks/struts/springs are the starting base along with a good set of tires, then some good rear lower control arms and subframe connectors and you're on your way to a solid street/occasional track set-up.
cool yeh im doing some research right now. now, this car is going to see quite a bit of street driving...maybe 5% of that at the track, so is a drag setup worth it? i mean, if im going to be hitting corners hard and fast, i suppose i wouldnt want that setup right? because from what i understand, in a drag setup, the struts help it lift off the ground (which is good for drag right) and there is an airbag in the rear right (from what i see in the item descrptions). would i be better off going for just a kyb kit from 50resto that ($390 improvesride handling %comfort) or get the drag kit from them for about $500 (lakewood.) either way im doing subframe connectors, not sure if removing the front sway bar is worth it in my case.
ah screw it, i remember seeing those coil over kits for like $2,000 and thats way out of the price range for a college student lol. i think i'll stick with getting a kyb complete shock, strut, spring kit for now. thanks alot man, i needed that insight!
whoa! we're not talking about the same coilovers, you're talking about a full kit, i mean just a front sleeve, it's about 250$. i'd at least get adjustable shocks/struts, those KYBs are meant for stock replacements, they just matched them with better springs.
ORIGINAL: 5liter87
mega-bite jr LCA's will improve handling and hook in a HUGE way
the right side airbag ($30 by itself) helps launch a lot
kyb at all corners will be noticible alot
energy suspension poly kit with everything else i said will make it handle like an older vette , and also increase the traction loads
but the bottom line is this, w/out a good tire (no street tire will do gotta be a DR or better) you will never be able to launch any higher than idle and slip the clutch til your going, it just won't happen , hook is MOSTLY about the tire
but the things i said will drastically improve handling, and greatly help traction
mega-bite jr LCA's
