i've tried everything and my turn signals still dont work...
ok i'm starting to get pretty pissed at my car. i've check all the wiring, and replaced every bad fuse. messed with the ignition and all that jazz. i replaced my multifuction switch about 2 months ago, so it should still be good. i think i'm just going to take the car to the shooting range and rock and roll with some ammo. any help here would be awesome.
RE: i've tried everything and my turn signals still dont work...
Even though the switch is a couple months old, it could have gone bad... If you got a meter you could ohm it out, that'll at least tell you if it's that or not...
put your hazards on, if they work, replace the switch and use dielectric grease on the connector
if the hazards dont work, replace the hazzard light switch
if you fiddle with the switch and something works, check all your terminals for tightness
try all above witht the car running so you dont drain the battery. some cars, a blown bulb will cause headaches
i'll check the hazards and see what comes of that. and no, i haven't checked the ignition switch, can i get a new one at autozone or something???
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
