throttle body and EGR swap
would it be alright to put a 70mm Holly throttle body on a BBK or summit 70mm EGR spacer?
as soon as i put my motor back together, and took the tape off the butterfly valve on the Throttle body, a huge chuck came off with the tape. so now i need to get a new throttle body and EGR.. any ideas of some of the best combos out there. from people who actually have the p;roduct? thanks
RE: throttle body and EGR swap
well im goin to pull off both the stock Throttle body and EGR. and when the parts come..i plan to port match the two for the bigger setup. 70mm is ok..so i heard. but 75mm would kill the TR.
What H/C/I setup are you running? Unless you have high flowing heads or boost, you probably will lose some throttle response w/ that 70mm. I'm running ported E7's, E cam, and the Street Heat intake w/ a 65mm TB....she runs guud (good)
i just have the basic bolt ons(longtube headers, costom 2 1/2 hpipe and flowmasters, ac eliminator, eletric fan, intake. underdrive pullys. thats about it...
but the chunk is only missing on the edge..will it be ok
