AODE to C4
Old 01-07-2007, 10:16 PM
musclemustang94
musclemustang94's Avatar
Default AODE to C4
Is thisa tough swap? I have a friend considering it and is more than likely going to do it since c4's are pretty cheap.
musclemustang94 is offline
Old 01-08-2007, 01:11 AM
musclemustang94
Default RE: AODE to C4
BUMP
Old 01-08-2007, 01:13 AM
bdwjdw
bdwjdw's Avatar
Nothing hard about it.
bdwjdw is offline
Old 01-08-2007, 01:28 AM
musclemustang94
Is it a direct swap? no computer crap needs done? just a driveline and the trans? what about the cross member?
Old 01-08-2007, 01:35 AM
bdwjdw
bdwjdw's Avatar
He will need the driveshaft spacer from Ford Racing, and the cross member will need to be moddified. I used the stock one and welded a plate to it so it would extend further foward, then just drill the holes for the tranny mount in the plate. I don't think you will have to mess with the computer but I'm not positive. What year mustang is it and I am assuming it is a 5.0
bdwjdw is offline
1BIGMOFO
1BIGMOFO's Avatar
I was going to do it i am about 80% sure you DO need to take the cross member out and relocate it. also you will need to have a drive shaft made, It wont be the same length. Im not shure about the computer? I built my aode up and threw a 2800 stall in it.
1BIGMOFO is offline
Ryan Fitzpatrick
09-14-2015 02:21 AM
CarrieS
09-01-2015 01:00 PM
TAC_Sisco
01-08-2004 06:33 AM
89 GT
11-18-2003 03:24 PM
MustangGT95
07-31-2003 02:56 AM
Quick Reply: AODE to C4
