95 stang opinion
95 stang opinion
i got a 95 gt and im gonna fix it up a little bit. im rebuilding it to a 306, then the following is goin in.
Trick Flow Kit TFS-K514-350-370B
BBK Full Length 1 5/8" Headers
24# Injectors
75mm Mass Air Flow Sensor
75mm BBK Trottle Body
75mm Trick Flow Throttle Body Adapter
Cold air intake
the TF kit makes 350hp and 370tq. with the 306, 24#injectors, 10* base timing, mass air, 190lph fuel pump, 9.5:1 compression, & 70mm throttle body.
once i get the block bored im gonna get the pistons from TF to match. im going to try and run 10.5:1 timing.
its an automatic and im going to put a shift kit in it also. does anyone have an idea what the car will run in the 1/4?
24# Injectors
Cold air intake
