will new intake fit under stock hood?
i gotta 88gt, i bought a tf street heat intake, and was wondering if a 1 inch spacer would fit under a stock hood, or if the 3/8's would? i'd prefer 1 inch.... but not sure if any will fit, what do you guys think? thanks alot
RE: will new intake fit under stock hood?
one way to test is to stick something that is 1" tall on the highest point of your intake and see if you can close the hood. if not, try a 3/8th. i have an aftermarket intake manifold and the heat sheild sits on the top of the manifold.
USE CLAY! If you use somthing hard you run the chance of denting your hood from the under side of it. Just get some clay and mold it to whatever size you need to check with.
you mean to tell me no one has tried fitting a trick flow street heat intake under a stock 88gt hood with any size spacer? i guess i'll go without a spacer, and get a cowl hood later down the road, and get the fattest spacer availible... what is the thickest you could or should go? any ideas? thanks
acer do you think im a fukin dumbass..... i just bought the intake and wanted to know if i should fuking buy a godamn spacer with it now or just do it later, its a real easy question, i hear people all the time talking about spacers and stock hoods and what not, and was just wondering.... so if you wanna buy me the damn dollars worth of clay go ahead, but its not worth my time
Well, sip sh*t... Send me your address and I will send you some clay...
After I ALREADY APOLOGIZED...
Someone should steal your car.... If performance isn't worht 10 minutes to the local store and $1 worth of clay, then drive a f***ing Geo Metro.
I dunno wtf it is with people... It was a simple jab, go buy some clay and find out! You seemed insulted that no one had your setup.
And for the record.... If it makes you feel better, yes, yes I do.
ok dumbass, how much difference could a fuking spacer make? not enough to get a new hood right now... i dont need you to send me clay, i got more money than you would know what to do with... so why dont you just take your honda and get the hell outa here! you probobly get your shiit from kregans anyways... fuking wallmart even dumbass
