tps voltage screwy
RE: tps voltage screwy
well by rotate do you mean move the rubber outside about an 18th inch side to side because thats all i can do with it...when i do that it doesn't change the voltage at all. you might be right about millivolts...i'm new to voltometers
you loosen the two screws on it; they attach it to the throttle body. then you can rotate it slightly to get the voltage that you want. sometimes you have to elongate the holes.
http://www.allfordmustangs.com/Detailed/581.shtml
jwog666
12-27-2021 08:09 PM
69MustangCoupe393cid
10-03-2015 10:33 AM
TfcCDR
09-14-2015 12:08 PM
