tps voltage screwy
tps voltage screwy
whether the car is on off or revving the tps is always reading 5.09volts from the green wire...isn't it suppose to be .97 with the car off and raise in volts as the car revs up? if so does that sound like a bad sensor or is something else causing it?
RE: tps voltage screwy
YOU don't test it with the car running dummy....you can just open the throttle with you hand to see how much voltage is has likely around 4.6 or so..get a new TPS..total volt on it's system is only 5.0 volts
ORIGINAL: 2 kwik
In order to check the sweep of the tps though, you will want to shut the car off [&:]
Also, the tps does not need to be set to exactly .998v.
As far as the computer knows, any thing between .6 or .7 through 1.1 or 1.2v indicates a properly functioning tps.
WOT is set as 2.7v over the base idle voltage.
Which means that WOT is not a set in stone voltage.
The DG/LG wire should have 5v with the connector unplugged. Plugged in, it should be near 1v. There should be a load capable ground on the BK/WH wire and a load capable (lights a light dimly) on the O/W wire. The O/W is your 5v VREF.
well the ignition was on but the motor wasn't running and both the green and red wire showed 5.09 volts. theni just turned it on for ****s n giggles and while revving it even nothing changed...nor at idle either. its always 5.09volts both wires no matter waht i do
