GEAR OIL T5
RE: GEAR OIL T5
yeah i herd synthetic if deff the way to go....i aslo bought some stuff called lucas tranny repair or something....its supposed to make it easier to shift and re-seal gaskets and stuff....have any of you herd of that...anyone know if it really works?
thanks
thanks
RE: GEAR OIL T5
ORIGINAL: five0fm
yeah i just wanted to make sure you could use ATF in the T5's. i got some already soo well see how that works....thanks for you input guys big help
RE: GEAR OIL T5
My 2nd gear syncro is horrible, and i have to baby it into gear. But i noticed that when the trans is cold, it shifts easier. Does this mean filling the trans with heavier fluid will make it shift better? If so what is a good heavy fluid?
RE: GEAR OIL T5
DON'T use anything other than ATF in a WC t-5 it ****s things up bad... if you are selling the car andthe tranny is bad use 80W90 to make it quite but don't drive your car with it and ecpect the tranny to last... synthetic oil is more slick (bad wording but the only thing i can thing of) so it lets things slide in easier...
i suggest changing the fluid every 75000-100000 miles i personaly change mine every 9000-12000, the more you change the fluid the cleaner it'll be which will le tthe tranny live longer... and yes the shifter is the easiest way to fill the tranny, how ever don't drive it right after let it sit for 30 min. - an hour to let the fluid settle in the main case rather than the tail shaft...
and that lucus stuff is useless on a T-5 since there is only one seal and a few o rings and no gaskets but on a tranny with gaskets and seal or an auto that stuff works wonders depending on how bad the tranny is
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
