how much hp & tq should i be making once i put all this on?
How much hp and tq should i be making(((without the Nitrous shot)))once i put all my stuff on my car, first off i got the car for 100 dollars since i work at my dads auto shop and a customor brought the car in and assumed that the intake manifold was cracked and it had a blown head gasket and wanted to junk it asap, so i gave 100 dollars for it, turned out it need a waterpump, radiator and a thermostat and is now running perfect, stalls when cold but otherwise pretty good. Here is the list of what i have so far for the car, my dad can show me how to put all of it on if i get stuck or antying sincec im only 18 and dont know everything yet,I also have a 2001 lincoln LS that i take to car shows but there was really nothing to do engine wise fore that car even though it was a v8...jaguar engine so very limited things. anyway heres all the stuff i have accumulated since spetember for the car... getting ready to put it on and want to know what u guys htink of the setup and if theres anything else i should get that would make it run smoother and add some more power also i dont want a supercharger or turbo just yet...
Trickflow Aluminum Twisted wedge track heat ported heads
2.02 INTAKE VALVES AND 1.60 EXHAUST VALVES
TRICK FLOW DOUBLE VALVE SPRINGS FOR UP TO A .700 LIFT CAM
heads milled .010 to 59cc combustion chamber
205cc intake volume
ported to a felpro 1250
3 angle valve job
Trickflow Stage 2 cam .542 lift
1.6 rockers(dont have them yet but i assume i shold get these)
Polished ford motorsport cobra intake manifold
70mm tb
BBK fenderwall intake
CAM 1 5/8 shorty polished stainless steel headers
MAC offroad hpipe
Magnaflow catback exhuast
transgo shift kit
tran cooler
3.73 gears
Tires/rims (still not set on them need help here also)
Zex 75-125 wet shot
also no this dont matter for that stuff but i picked up a seat of front and rear seats, with that black tweed and black vinyl in mint condition today for 200 dollars.
Finally if there is anything else i should get let me know cuz im pretty new to the whole performance engien upgrades, i want the car to be streetable and be able to be taken to the track on occasion.
Will post pics of the car soon, also whenever the engine is done i will show pics before i drop it in... and pics after
Just help me out with some input its greatly appreciated thanks
Korey
205cc intake volume
3 angle valve job
70mm tb
MAC offroad hpipe
transgo shift kit
tran cooler
3.73 gears
Zex 75-125 wet shot
Korey
RE: how much hp & tq should i be making once i put all this on?
i also have a question, can i use a stroker kit on the engine and still be able to use all my bolt ons and how much would i beneft from doing that if so...if not hwat are some other tihngs i could add besides a supercharger taht would add some more hp
1-400 flywheel hp..to guess with out specifics is dumb...ya need cam specs,air flow #s on heads,weight,comp,all thats n more to get a close guess....
