Instrument Cluster Swap 87-89 to 90-93
RE: Instrument Cluster Swap 87-89 to 90-93
ORIGINAL: 5.flow
last summer i bought an instrument cluster out of a 92 gt for my 87 gt without even considering the possibility that they could be differnet. what a huge mistake. i didnt try modding it tohugh, looked at the back and it didnt evne look like it could plug in so i said f*ck it. i took the guts out hoping i could lay the clusters in place in the old shell. noooope. i bet someone who knows what they're doing cna make it work though. i just kept the speedo gear and am gonna just buy the damn faces. i think you can do that, does anyone know?
i just did mine it my 89 gt.swapped from a 91 gt with the 140 speedo it honestly hooked up perfectly,but the elctronic lights for like airbag an everything will stay on all the time if u have a 87-89 an put a 90-93 cluster in i just took the speedo out an placed it in the 89 bezzel works perfrect
This is what it looks like all torn down.
As you can see in Jays89GT's pic, there are 3 connections to worry about, one cable for the speedo, and 2 connections for the electronics, on the right and on the bottom left.
As for the fitment between the 2, I don't know anything about that, I had an 88 Cluster and swapped for a 140 from an 88/89, which was just plug and play.
Matt's 95 Stang
10-05-2015 07:16 AM
87, 8789, 89, 90, 9093, 93, cluster, dash, gt, installing, instrament, instrument, mustang, swap, v8
