how do delete the heater core ?
RE: how do delete the heater core ?
ORIGINAL: 88 GT n loven it....
ok thanks .... i get it now im suppost to connect both the hoses together, does anyone know what size ofconnector will i need and do you guysknow if it's ok to use a plastic one ?
Go to your local parts store. Get a brass adapter that goes to 5/8 to 3/4 inch. (It's made out of brass) In the HELP section of the store. Then connect the two lines near the back of the engine, that also come off of the engine, and hook them together with this adapter. FIXED, and COLD.
Good luck.
Good luck.
i did this on my 86 when i got it a few years ago, heater core drain nub started leaking, i just bypassed it at the back of the motor where the two coolant lines run to the heatercore, fixed and cool like he said and cost me 5 bucks at napa to get a flexed coolant hose, 5 min job..... better than it flooding into your passenger side
Why does everyone cry about this so much?? It's easy to replace, the dash comes off but you dont have to unhook any wiring, I just did mine. Its nowhere as near as bad as people said it would be. Just take your time, label your parts..etc. Even if you can rough the winter, do you really want your winshield fogging up all the time? Pain in the ***.. its better to just get it fixed... it'l take about 5-6 hours.
It won't effect it at all. All that core does is hold the hot water so air can blow across it in the heater box so you have heat. You shouldn't have anything to worry about, and i know how you feel on the temperature part, cuz when i bought my car it had already been bypassed. So i've been freezin the last month or so.
Most people don't drive 5.0L mustangs in the winter time anyways. Usually theres a couple feet of snow... or at least trace. Bypass is a easy fix til someone has more time to tackle the project, and depending on the model year replacement can be easy or time consuming, either way its not something I think anyone looks forward to.
ORIGINAL: 7upedition
