does anyone know anything about.....
RE: does anyone know anything about.....
ORIGINAL: carsurplus
will it make sound so before it idles you cn really hear the engine
Just get a cold air intake... it adds power and then you can get rid of that ugly black stock junk.
maybe it had no fan shroud? Or a vacuum leak?
It wouldnt be the silencer making a loud "air" noise if the silencer is still on the car. The only time you should hear air sucking is when you hit the throttle
Air Silencer is used to restrict and quiet air flow into the the MAF and into the Intake, removes with a few bolts and drops out through the fenderwell, well worth removing.
like ok hes the dealim buying a stang 88 super clean when i turned it on i heared a lot of air what could b the problem?? could it b the air silencer
https://mustangforums.com/m_2540018/...tm.htm#2540128
PistolPez73
22
08-02-2009 11:20 PM
