KING COBRA CLUTCH
RE: KING COBRA CLUTCH
ORIGINAL: GreenHornet92
I have it and it is awesome. Like stated above, you will get used to it. Just a fair warning, don't drive the stang to the gym on leg day.....don't ask how I know
ORIGINAL: shaners90lxhatch
Mines nasty too man. I still don't know if I have an aftermarket quadrant and/or and adjuster. I am pretty sure I do, but it's so stiff I had to scoot the seat up or else I just push myself back. I can't drive mine in bad traffic either. The 10% less pedal effort I believe is a comparision with the older KC or other heavy duty clutches. If you figure out a fix let me know, short of ripping all my junk off and installing it myself, I don't know what else to do.
edit: i mean to the right of the wheel, my bad
ORIGINAL: 90Lxstanger
You should be able to look under the dash to the leftof the steering wheel and you'll be able to see if youhave a aftermarket quadrant, the firewall adjuster should be mounted on the firewall and you definaetly cant miss it(right under or around the brake booster) +1 cable clutches are hella harder then hydralic, but they do m ake forsmoother shifter, better then a Honda anyway, I got used to mice pretty quick, my leg never got sore though, igot a Ram Heavy Duty clutch, and aftermarketcable kit.I dont know what a stock cable feels like though.
i did this and my left leg kept twitching! driving the car home that night was the hardest thing ever!
i just got a new kc clutch in yesterday. sooo much beter than the original, very bald disc, throwout bearingnot turnable by hand!
it is easier to dis-engage
ORIGINAL: 89Ford
haha did the same thing, on the first day working out my legs, big mistake
i did the same thing but o well... i'm used to it now.. and a good way to get used to a stiff clutch is to get a gym membership... after a month or so you'll think ur driving a hydrolic clutch car lol
ORIGINAL: ModularFox
mines super hard to press..infact ive broke 2 clutch cables because of it. i just ordered a aftermarket cable, quadrant, and firewall adjuster, im hoping it will help out. I also had to use washers too. my buddys 90 lx has a spec stage 2 in it, and i love driving his car, its super easy to press. ive even broke my seat now because its so hard to press. i cant wait to **** can it and get my spec.
my center force isn't exactly light, but it's much lighter than the cobra
ORIGINAL: AdderMk2
king cobra clutches suck.... Spec and centerforce are both really light clutches that will hold ALOT more power
I need help too. My clutch is hard as a rock. I have replaced every component. I had a king cobra clutch and it was hard as a rock so I bought a spec stage 2 and it is even harder. I replaced the clutch fork, pivot ball, pilot bearing, throughout bearing, UPR adjustable clutch cable,steel bearing retainer, I even replaced the bushings in the pedals the control your side to side movement. It is also chattering when I release the clutch out even more when in reverse . I was told something with the throughout bearing. I just don't know what else to do.
