E303 doesnt work with afr 165s??
So I put my car back together and I have an E303, afr 165s 60cc combustion chambers, and 1.7 crane roller rockers pedestal mount that are factory on the cobras. Tried to start it, and it was only making vaccum. Tried taking off the valve covers and adjusting the rocker arms on both sides and no matter what it would make no compression. So either the E303 for some reason doesnt work or it is installed wrong which makes no sense cause i know the timing dots are lined up and the cam pin went through the key hole. This doesn't make sense to me because I know that the E303 is a pretty basic old school cam.... Any help would be appreciated.
RE: E303 doesnt work with afr 165s??
It must be timed wrong. The heads and cam should work extremely well together - you are not the only one with this combo. Perhaps you got the wrong cam, but jeez. If your rockers where too big, you'd bend the valves first time it cranked over. You need to do some leakage testing with the rockers off.
ORIGINAL: seanjohncombs001
Is this supposed to just be a random comment that makes no sense lol
you need a tune!
