O2 sensor help
O2 sensor help
Ok, first off, I have no cats. I long tube headers with the O2 sensors in place. They both need to be replaced. With the cats missing, are the O2 sensors really reading correctly? Can I just install those O2 eliminators that Jegs sells, if so, will the ECM read correctly for the A/F ratio?
Please help!!!
Please help!!!
RE: O2 sensor help
The emulators are for downstreams, I believe. The upstreams will read correctly given they are the right part, placed in the proper location (very likely good if your headers have ports for them) and the heater is operational. Stick some new ones in and you're good. Best to test the wiring as well, but if they work well now, they should work well installed in the headers. Mine do
RE: O2 sensor help
These are Heddman headers. The O2 sensors are located right before the collector output flange, on the inside facing the tranny.
I don't think they are factory installed bungs the weld looks too sloppy.
RE: O2 sensor help
dont buy the extensions its a waste of money. i just extended them myself w/ the same guage wire, and soldered then and then used heat shrink to seal them all up. its free instead of payin 50 bones for 1 foot of wire.
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
