351 in a sn 95???
#22
RE: 351 in a sn 95???
ORIGINAL: 94 G STANG
JUST BORE OUT THE STOCK HEADS??? HOW MUCH WOULD YOU EXPECT TO PAY FOR PORT AND POLISH HEADS MORE OR LESS?
There is only 1 year of 351w heads that are any good. I think it was the 69 casting? After that the 351w heads are basically the same as the 302/5.0 heads.
Which means they suck.
Most any aftermarket head (I consider the GT40 to be aftermarket) can accept 2.020/1.6 valves.
There may be exceptions, but I can't think of any?
The GT40's may limit power, but they should do fairly well. Alot better than any ported stock head will do anyway!
For the cam, look for something with slightly more duration than what you would consider for an equivelant 302.
check my site for some more 351w swap stuff...
good luck,
jason
#23
ORIGINAL: AdderMk2
... if a FSTB was so damn good... why didnt 6,009 cobra built in 1994 come equipped with one?
ORIGINAL: vristang
Adder- How can you say a strut brace isn't doing any good, especially in a vert?
BTW, the 96 and 97 Cobras had a strut tower brace. Using your logic, it must do something then, eh?
#25
ORIGINAL: pizzarolls
yea adder!!!! j/k.....im with u on the brace......i wasn't impressed by the one i had. and screw the hole money theory....im sure ford can afford it.
#26
ORIGINAL: vristang
My memory is fuzzy on this so double check me...
good luck,
jason
good luck,
jason
-P.
Mustangs of Illinois
08-22-2015 10:00 PM
