Trick flow manfold
RE: Trick flow manfold
Just swapping the intake will not really give u all that much hp and prob wouldnt even really feel a big diff untill u gethead Also get a cam. Just save and get it done all at once. I run a trikflow intake ()only) i like it but i wish i would have went withan box intake!! But i hear edlebrock makes the best intakes but that what ive heard only.
Yes, it will be less restrictive that a stock intake, but to really maximize your motors ability, you'll need:
-Heads/Cam/Intake Combo (Trickflow Street Heat)
-Larger MAF (C&L 76mm)
-Larger TB/EGR Plate (70mm)
-If your exhaust is stock you'll need to set it up for 2 1/2" free flowing
Good Luck... if your on a budget look at ebay and classifieds sections.
ORIGINAL: disturbed471985
good info guys....thanks alot. how about if i just change the heads and intake manifold? do i need to take out my engine to change the cam?? or is there any way without pulling out the engine?
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
