Procharger P600B pulley question
I have a pulley formyp600 Prochargerand I need to know how much boost it will make on my 5.0. The pulley is 3 1/8' diameter to the widest part and about 2 5/8' diameterat the surface that contacts the belt. I bought it used and have no idea if its what I need (14# pulley).
RE: Procharger P600B pulley question
Typically the P600B's don't make a whole lot of boost. They have a poor impellar design which holds them back quite a bit. Procharger states that if you stick it on a stock motor you will see almost 12-13 PSI with the smallest pulley. On my h/c/i LX I usually only saw about 6-7 normally and 8 on a good day. I was also running the smaller pulley. It is a good kit to start with though and you can alsways upgrade to a P1SC.
treesloth
09-28-2015 07:03 AM
