Boost/fuel pres/ air fuel gauges
Getting all of my gauges installed this week. Was wondering if somone knew which wires are the o2 censors that go into the computer so I can hook up my air fuel gauge to them? I assume thats where they hook to ? Or a wiring diagram?I bought the auto meter NV's, and I also bought the bezel that puts the gauges under the radio. I am thinking about turning it upside down so the gauges are on top of the radio and easier to read. I will see how it looks and post some pics later. thanks for any help!
RE: Boost/fuel pres/ air fuel gauges
Hey check out www.fordfuelinjection.comand look the the EEC part i think the have a pic that tells what all the pins are, i cant remember for sure of the top of the head though
Here ya go Im pretty sure this the the pins and what the relate to, if someone could back me up on this tho.....
Pin #
Wire Color
Connections for a 88-93 5.0L HO Mustang
Value at Idle
01
YEL
+12 Battery Voltage
12-14 volts
03
DG/WHT
VSS + / Vehicle Speed Sensor Positive
55MPH = 125hz
04
DG/Y
IDM / Ignition Diagnostic Monitor (TFI)
20-31hz
06
ORG/YEL
VSS - / Vehicle Speed Sensor Negitive
55MPH = 125hz
07
LG/RED
ECT / Engine Coolant Temp Sensor
0.5 volts = 200*F
09
TAN/BLU
MAF RTN / Mass Air Flow Return
< 0.1volts
12
BRN/YEL
Fuel Injector 3
4.9-5.2ms duty cycle
13
BRN/BLU
Fuel Injector 4
14
TAN/ORG
Fuel Injector 5
15
LG/ORG
Fuel Injector 6
16
BLK/ORG
Ignition Ground (TFI)
17
TAN
MIL / Engine Light & STO / Self-Test Output
ON = GND
19
DG/YEL
FPM / Fuel Pump Monitor
Pump on = 12-14volts
20
BLK
Ground
< 0.1volts
21
WHT/BLU
IAB / Idle Air Bypass
3.0 - 12.0 volts
22
BLU/ORG
FPR / Fuel Pump Relay
ON = GND
25
GRAY
ACT / Air Charge Temp Sensor
3 volts = 70*F
26
ORG/WHT
Voltage Reference
4.9-5.1 volts
29
DK GRN
Right HEGO
0.0-1.0 volts
30
BLU/YEL
Transmission Neutral Interface
0.0 volts in neutral
36
YEL/LGRN
SPOUT / Spark Output Signal (TFI)
37
RED
EEC Relay +12 volts
12-14 volts
40
BLK
Ground
< 0.1 volt
42
TAN/RED
Fuel Injector 7
43
DK BLU
Left HEGO
0.0-1.0 volts
45
GRN/BLK
BP / Barometric Pressure Sensor
159hz = sea level
46
GRY/RED
Signal Return
0.1 volts
47
DK GRN
TPS / Throttle Position Sensor
0.9 volts
48
TAN/RED
STI / Self-Test Input
GND = Self-Test
49
ORG
Ground
< 0.1 volt
50
BLU/RED
MAF / Mass Air Flow Sensor
0.8 volts
52
LT BLU
Fuel Injector 8
56
DK BLU
PIP / Profile Ignition Pickup (TFI)
57
RED
EEC Relay +12 volts
12-14 volts
58
TAN/RED
Fuel Injector 1
59
TAN/ORG
Fuel Injector 2
60
BLK
Ground
< 0.1volt
Pin #
Wire Color
Value at Idle
01
YEL
+12 Battery Voltage
12-14 volts
03
DG/WHT
55MPH = 125hz
04
DG/Y
20-31hz
06
ORG/YEL
55MPH = 125hz
07
LG/RED
0.5 volts = 200*F
09
TAN/BLU
< 0.1volts
12
BRN/YEL
Fuel Injector 3
13
BRN/BLU
Fuel Injector 4
14
TAN/ORG
Fuel Injector 5
15
LG/ORG
Fuel Injector 6
16
BLK/ORG
17
TAN
ON = GND
19
DG/YEL
20
BLK
Ground
< 0.1volts
21
WHT/BLU
3.0 - 12.0 volts
22
BLU/ORG
ON = GND
25
GRAY
3 volts = 70*F
26
ORG/WHT
Voltage Reference
4.9-5.1 volts
29
DK GRN
Right HEGO
0.0-1.0 volts
30
BLU/YEL
36
YEL/LGRN
37
RED
EEC Relay +12 volts
12-14 volts
40
BLK
Ground
< 0.1 volt
42
TAN/RED
Fuel Injector 7
43
DK BLU
Left HEGO
0.0-1.0 volts
45
GRN/BLK
159hz = sea level
46
GRY/RED
Signal Return
0.1 volts
47
DK GRN
0.9 volts
48
TAN/RED
GND = Self-Test
49
ORG
Ground
< 0.1 volt
50
BLU/RED
0.8 volts
52
LT BLU
Fuel Injector 8
56
DK BLU
57
RED
EEC Relay +12 volts
12-14 volts
58
TAN/RED
Fuel Injector 1
59
TAN/ORG
Fuel Injector 2
60
BLK
Ground
< 0.1volt
