Question on smog eliminator!!!! Help
Im getting ready to buy a smog pump eliminator and the only one Ive seen that has 2 holes is the one from ford racing. Now instinct tells me that is Ford built it, it will fit right but at the same time if I can get an $80 piece for $50 then you know. But the other brands only have one mounting hole. Does anyone have a smog eliminator and if so could you give me any info/testimonies on how you like it. Thanks.
RE: Question on smog eliminator!!!! Help
i've got the ford racing one i bought from summit:
http://store.summitracing.com/partde...5&autoview=sku
it works fine but sits a little at an angle and eats my belt up; have to replace belt every other month. i think it's probably the bracket the eliminator mounts in and not the eliminator itself but havent got around to checking it.
why not just take off the smog pump and run a short belt, that's what i did, it only cost me a new belt. run a piece of string around the pulleys and get a measurement. good luck
ORIGINAL: Mike93SVT
770k6 for a stock routing with just a new belt instead of getting a eliminator
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
