MGW
RE: MGW
First off, w/ the MGW you can position the shifter anywhere you want it. The throws between shifts will be shorter and more precise...not as mushy feeling as the stocker (<--most short-throw shifters will do that for you). It will also help your 2-3 shifts be more accurate due to spring tension that helps the shifter center between gears.
RE: MGW
When my times comes to buy one ( whenever i have the money ) i'll definatly be buying a MGW shifter, i hear nothing but great things about them, and you wont be wasting your money, its a wise investment.
RE: MGW
also is it the shifter or tranny or clutch that makes some of my throwsmore stiff almost to the point to where i have touse a little bit of umpfbehind it.( it only happens on occasion)im trying to find a fix so i can rip the gears....
CMcNam
10-30-2022 11:40 PM
Juztang
12-12-2005 10:03 PM
Code3Smith
11-08-2005 06:58 PM
