My quote from dss
My quote from dss
I went to DSS racing and asked for a quote on a new engine cause mine is taking a crap on my face. so i just want an easy swap with tons of hp and blower/nitrous ready and this is what they sent me. Is it worth the $6000 bucks? And i already have a new rear end and tranny thats not in my sig no worries on that part. Lemme know what you guys think though thanks!
347SB2004 PRO BULLET Max Quench/IN/TW: 347 cid short block for use with most inline valve
and Twisted Wedge cylinder heads and will accept large cams and large valves.
Balanced to racing tolerances and blueprinted, forged DSS Pro Series pistons,
assembled in a Level 10 CNC block with the billet aluminum Main Support System
installed with custom ARP main studs.
*LIMITED TIME OFFER, FREE UPGRADE TO PRO-X FORGED PISTONS - This
upgrade includes an ultra-lightweight design, bigger valve reliefs, and a
hi-tech/low-drag ring package.
BLOCK: Level 10 CNC block - deck equalized and squared, deck plate bored and
honed in CV616 with sub 10 micron filtered man-845 honing oil, and numerous other
CNC operations. RODS: forged 5.400" I-beams w/ ARP bolts & full floating pins,
CRANK: nodular iron 3.40" stroke, PISTONS: forged Pro-X # 4337 (Max
Quench/IN/TW -18cc), RINGS: moly E-458K, ROD BEARINGS: tri-metal CB-634P,
MAIN BEARINGS: tri-metal BC240J, CAM BEARINGS: tri-metal CC440
2,659.95 2,659.95T
Track Heat longblock LONGBLOCK UPGRADE: Final assembly of a shortblock with heads, rockers, and
all other necessary parts listed below to complete the long block assembly. This
critical step in the assembly process is the key to long life and maximum power.
Checking and correcting rocker arm geometry, adjusting pushrod length, and setting
lifter pre-load is very time consuming but pays big dividends in power and longevity.
These often overlooked steps are included in this longblock assembly.
PARTS: CYLINDER HEADS: Trick Flow Track Heat CAMSHAFT: Ford Racing
TIMING CHAIN: Pro Gear 3 Position Double Roller 430HDSTK LIFTERS: Ford
Racing RETAINING HARDWARE: Hydraulic (when necessary) PUSHRODS: 4130
.080" Wall Seamless HEAD BOLTS: ARP 8740 Hex Head Bolts HEAD GASKETS:
Fel Pro Graphite 8548 PT2 ROCKER ARMS: DSS Aluminum Roller Rockers
T-WASHERS: 1/2" to 7/16" reducer bushings for cylinder heads (where applicable)
2,655.00 2,655.00T
Upgrade to ARP head studs Upgrade to ARP head studs from ARP head bolts 50.00 50.00T
Upgrade to premium hyd ... Upgrade to premium hyd roller camshaft listed below 150.00 150.00T
B-41 Anderson Ford Motorsport B-41 Blower Camshaft (6500 shift/2800-3000 converter) 0.00 0.00T
Power Package #2 302
208 28oz SFI SBF balancer 1 299.95 299.95T
286501 Fidanza SBF 157T/late model SFI steel flywheel (0, 28, or 50oz balance, replaceable
friction surface)
1 239.95 239.95T
7005 DSS 5.0 STROKER Pro Tray windage tray 1 109.95 109.95T
100-2801 ARP flywheel bolts 7/16" x 1.00" 6pcs (manual trans) 12.95 12.95T
150-2501 ARP balancer bolt 289-460 except 351C 1 19.95 19.95T
302 Package #2 discount 302 Package #2 discount -64.75 -64.75
Power Package #2 302 618.00
Page 2
$6,132.95
2,659.95 2,659.95T
2,655.00 2,655.00T
friction surface)
1 239.95 239.95T
Page 2
$6,132.95
RE: My quote from dss
You know...I probably had over 7000 in the last 408 I built, but I never paid it any mind, I built it myself. I guess it is all a matter of what you wanna do. The 347 used to be one of THE favorite blower motor platforms. But for the kinda cash they are going to hit your for, I would HAVE to go up to the Windsor base. That is just me, in a 4blt main FTW
CNC block and TW heads alone woudl add up to 3 wouldnt it?? Not to mention theyre gonan assemble everything and itll be balanced. For all the work theyre doing and all the parts that are with it, it doesnt really sound all that bad. Granted if you did it yourself it would be cheaper, but that price tag isnt too far out.
Do they offer any sort of warranty?
-P.
-P.
A local engine builder would take more pride in your motor. You can find a deal on the TW heads online... I would look locally.
BTW, DSS uses stock blocks, not anything special...... A 351 will hold more power and has 4-bolt mains, like mentioned above.....
