Speedo Question
Speedo Question
I was wondering if i am going to have any problems with my speedo since I've converted to carb and put in a C4 tranny.I already converted from my 4 Cyl to aV8gauge cluster .
Speedo Question
The gear that came in your car should work just fine,it's possible that the speedo may be a little off depending on wether you have a 7 tooth or 8 tooth output shaft,all you can do is try it and see if the speedo is accurate.There should be a little clip on the gear that you just pop off with a little srewdriver,and yes it is located in the extension housing of the trans.
Speedo Question
yeah i looked at it tonight.Everything looked like it fit fine so I guess i'll just cross my fingers. no biggy if it's off alittle I just didn't want to be goingdown the road going 70 and thinking I'm going 55 hahaha. ThePo-poaround here would eat me alive with tickets
Speedo Question
You've successfully confused me.
The AOD came with the 4banger and the 7.5" rear end right?
And the C4 came with the 302?
Which rear end are you running? The 7.5 or did you put an 8.8 in?
Speedo Question
Ok here is the info , sorry to be confusing.</P>
My car was originally a 4 banger with an auto trans , I forgot what the name for it was, maybe like A4LD something like that. A 7.5 rear of coarse , and the 85 mph speedo and guages of a 4 cyl</P>
The 5.0 that I bought came with an AOD . But I took it off and went with a C4 instead. Still have a 7.5 rear end for now until i get money for gears to put in the 8.8 , then it will go in.</P>
So I have a 5.0 with a C4 and the guages are from a 5.0 (140 mph). I was just concerned that the transmission change would make the guage read wrong . When I saw that you guys said I might need another speedo gear I was curious if the one from the AOD I had setting here would work since it was standard equipment with the 5.0's. I wasn't sure if the gears would interchange or not.</P>
Again, sorry to be confusing. </P>
