Where to pour it
Where to pour it
I know, I know, not another thread about sea foam. But i've done searches on it, and can't decide where to pour the stuff. Can i pour it right into the carb? I want to know for certain before i go f****** anything up.
RE: Where to pour it
[ol]
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance. See label on can for detailed results for use in each area. [/ol]
FUEL TANK, CARBURETOR, INJECTION and OIL CRANKCASE. For Peak Performance, Use SEA FOAM Every 2,000 to 5,000 Miles
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
