my battery is dieing?
I know its an "in general" question but can anyone give me any ideas on what to look for and tell me why my battery is dieing after about 2 weeks? I ussaly drive about that often and usally get in it and have to put it on the charger.
I bought the car a while back and it had an aftermarket stero in it. Can this be it?
I drive it a little less than when I first had it so I can say what it was doing before?
RE: my battery is dieing?
First thing you need to do is check your connections. Make sure your battery cables are tight, and that they aren't corroded. Then you need to take a multimeter, and check your voltage with the car running. You should be pushing about 13.5VDC. If you don't have a multimeter, take your car to Advance or Autozone. They will check your charging system and your battery for free to see if it has a dead cell. When you say you have an aftermarket stereo, are you talking about a pioneer head unit, or a 6000w amp pushing 4 12"s and 2 15"s or something rediculous like that?
Vic
Vic
No its just a different radio than the stock one. It not pushing anything.................It does not power on when the ignition is off so its not wired direct.......??
I will take 93 LXs advice and go get it tested first and rule out any "idiot" issues first.
logan409
09-26-2015 07:43 PM
