What do you all think?
Since i am new to this whole thing, i turn to all of you who have done this before. I'm doing Cobra manifold, E303 cam, and i have the headers back exhaust upgraded. Leaving the heads stock. Everything else stock. Will the car fall on it's face if i didnt up the fuel or dyno tune? Keep in mind i have speed density setup not MAF. Thanks all
RE: What do you all think?
Really not much of a point in doing intake and a cam and not doing the heads, they all work together. Also keep in mind there are specific cams that only work with speed density, alot wont work well with them, i believe there is a sticky up top telling whcih cams will work with SD. And with those mods you wont need to up your fuel, you will be fine with a stock fuel system, maybe add a fuel pressure regulator and maybe a 155lph pump, but you'll prolly be fine with stock stuff. I'd hold off and get some heads to put on at the same time with the cam and intake, i'd upgrade to a MAF too, SD holds you back from doing alot.
ORIGINAL: Ninety5five0
